cheng
Member level 5
3D simulatoring
I quite don't get the yuyu argument about HFSS being not accurate on radiation problems. It is just absolutely contrary - YuYu I've tested hfss on almost any kind antennas (but reflector) and the one that matches nearly everything was hfss. How can you say it is not good for antennas while the prime strength of hfss is namely in the precise antenna simulations. I really don't get it. And its post processing maybe lacking the polish of MWS but is nontheless rock solid and offers better functionality. In antenna problems, what does matter is the proper sizing of B.C but to say that hfss is no good for antennas means to twist truth.
Next - I disagree that none of the SW but MWS on the above list is 3D. Simply it isn't true for some real cases 3D task in stratified media can be tons faster run with "2.5D" tool. Let's not get into useless discussion on what is a real 3D tool. Let's make it opposite - what is really 3D task to solve - which is much more correct. Else we are wasting efforts and time.
cheers,
Can you imagine a big dishy antenna being simulated with any of the above mentioned tools? - No, of course, that's where Ticra and the like come into being. So, there are different applications that call for different tools and not the other way around.
cheers,
