What is a TFT (Thin-Film Transistor) display?
aym_qunibi
Member level 4
Member level 4
what is tft tech?
and how we do a maintenance?
Re: tft display?
TFT (Thin-Film Transistor), also known as active-matrix, is a system in which the pixels on an LCD display are switched on by a transistor when it is strobed by the data. This gives a more reliable switching than the older STN displays, where the pixel is switched directly by the data lines. A capacitor is also added to keep the transistor switched on for longer after the data pulse has ended, giving a brighter display.
As to maintenance, there is nothing you can do if the unit has random bad pixels - the transistors are depositied on the glass.
Other failures that may be fixable are:
1) Poor contact between the LCD panel itself and the PCB (rubber strips) causing missing lines - needs realigning
2) Light too dim or out - replace fluorescent tube and/or inverter
3) Poor connector contacts causing intermittant operation or missing colours - clean/realign/replace
4) Electronic failure in driver circuitry - good luck!
See here for more info:
Hope this helps,
FoxyRick.
    aym_qunibi
Re: tft display?
Check out as I got from net may be of ur help .... It's seemed to be good to me as i have studied ....
