clock domain crossing
peen1
How do you move data from a fast clock domain to a slow clock domain?
I understand that if you move from slow to fast you can double flop with fast clock or use the fast domain to catch the falling edge of the slow clock and then latch in the data.
clock domain crossing handshake
using two clock domain FIFO or buffer, several ways to design it, find them out in this forum.
    V
clock+domain+crossing
You also can use handshake as a simple way.
Reactions: pdhama
    pdhama
passing clock domains handshake
still use fast clock to sample slow clock, then the delayed posedge of slow clock (this signal is synchronized to fast clock),if is signal is low, hold data in the slow domain , change the data output to fast clock domain only if this signal is high. In a word , avoiding changing data at the posedge of slow clock by holding the data under such occassions.
    V
clock doman
with faster clock domain in your design, you must define a efficient operation protocol for synchrony. the setup and hold time delay is key for consideration.
    V
cdc fast to slow clock domain
If we are taking about data lines then generally two techniques, using a protocol a simple protocol can work where an new data is indicated by a flag set and reset signal after data capture "u can use a flancter to do this". or the other ultimate choice is to use a async. FIFO. in both design you have to take care of metastability issue
Reactions: pdhama
    pdhama
fast to slow clock domain crossing circuits
hand shake is proper for low speed data transfer
FIFO is more common and much faster, but add difficult to your design
Reactions: pdhama
    pdhama
handshake crossing clock domain
If it is asyncronous signal , latch the i/p thru Flip Fliops (atleast 2 FF's) using Rx domain frequency .Here you will be losing 1 or 2 clks ,but probability of getting into Metastable is low.
Use FIFO for data lines & high speed transfers , but take care of FIFO depth.
Handshaking is also another method whereby one can sample the asyncronous signal using Handshaking signal from both the domains , here also speed matters at the cost of extra handshakes.
Reactions: pdhama
    pdhama
passing data from slow to fast clock domains
There are various techniques to handle CDC.
i am attaching a paper on CDC.
go through it. its realy a good paper.
    V
move data from slow to fast clock domain
use FIFO
    V
clock domain handshaking
you can use two phase handshaking protocol to passing data from
one clock domain to another clock domain,
if you want high speed, use a asynchronous dual port fifo to
realize your dream.
Added after 4 hours:
the attached file has some content on this problem.
Reactions: lorna8899
    lorna8899
    V
fast to slow crossing clock domains
use a dual port ram....and 2 counters to increment address....
increment the address of the read counter whenever not same as write counter
    V
signal crossing clock domains slower clock
Use handshake
    V
clock domain crossing fast to slow
Using handshake is the best option to avoid metastability.
    V
slow clock fast clock signal
Better go for Dual Port Ram or even Handshake Toggle Synchronizer....:D
    V
Use asynch fifo or handshake
    V
