You can refer to following sample chapter from "Digital Design Principles and Practices "
by John F. Wakerly www.ddpp.com/DDPP3_mkt/c06samp1.pdf
You try to describe it in verilog. If you face in difficulty let us know!
We will do it for you!! But its better you try first writing the code!
Hope this helps!
use case to synthesize a multipler. But it seems transistor array cannot be synthesized unless you use self-designed cells or plot the schematic and design it using analog method.
hi
simple code for barrel shifter is given in VHDL primer J. Bhaskar book but it is in VHDL . I think its logic can easily be converted to Verilog code
module Barrel_shifter_main(A,C0,C1,C2,C3,Q);
input [7:0]A;
input C0,C1,C2,C3;
output [7:0]Q;
reg [2:0]S;
always @ (C0 or C1 or C2 or C3)
if(C0) S=3'b001;
else if(C1) S=3'b011;
else if(C2) S=3'b101;
else if(C3) S=3'b111;
else S=3'b000;
barrel_shifter shfter(A,S,Q);
end module
The code for the 4x1 MUX used in the Shifter;
module mux(y,d0,d1,d2,d3,s);
input d3,d2,d1,d0;
input [1:0]s;
output y;
reg y;
always @ (d0 or d1 or d2 or d3 or s)
case (s)
2'b00:y=d0;
2'b01:y=d1;
2'b10:y=d2;
2'b11:y=d3;
endcase
end module
module mux8x1(y,d0,d1,d2,d3,d4,d5,d6,d7,s);
input d0,d1,d2,d3,d4,d5,d6,d7;
input [2:0] s;
output y;
reg y;
always @(d0 or d1 or d2 or d3 or d4 or d5 or d6 or d7 or s)
case (s)
3'b000:y=d0;
3'b001:y=d1;
3'b010:y=d2;
3'b011:y=d3;
3'b100:y=d4;
3'b101:y=d5;
3'b110:y=d6;
3'b111:y=d7;
endcase
end module
If you are using a Xilinx chip, take a look at this application note from Xilinx :
Implementing Barrel Shifters Using Multipliers ( available @ **broken link removed** )
It explains how touse embedded multipliers to design an efficient 32 bit barrel shifter, a sample application in VHDL and verilog is available @ **broken link removed** .
