How should I improve my circuit for squaring waveform input?
elonjia
Newbie level 6
Newbie level 6
the circuit is just like a bandpass amplifier above, and when I input a square waveform, the output is just like the yellow curve; how should I fix this?
By nature of bandpass filter, if the input waveform is a square wave, the output waveform will be different. Not clear what you want to achieve.
So it's good in terms of the waveform? I want to output to be the square waveform either, should I increase the bandwidth?
The whole point of a bandpass filter is to attenuate low and high frequencies. There's no way you can expect fast edges AND attenuated high frequencies. Fast edges=high frequency.
Thanks, could I move this high f to a higher freq so it has a better output performance? Also, is there any recommendation for the high-frequency circuit structure?
    FvM
Obviously, the lower (high-pass) cut-frequency is above fundamental input frequency, thus no chance to reproduce the waveform. I'd try factor 10 lower cut-off frequency (factor 10 larger coupling capacitors) as first step. Upper cut-off frequency doesn't seem to be critical.
what “noise” are you trying to filter? Maybe you just need a low pass filter, not a band pass. with zero requirements it’s impossible to give an intelligent answer. what’s your rise time requirement? what’s your pass and tprequirement?
I suggest a low-pass filter to remove high frequency noise (if needed), followed by a high-speed analog comparator (for example MCP6566) to generate a good square-wave.
A comparator with 80nS rise time isn’t going to give a very good square wave at 1MHz.
Again, with no specs, it’s pretty difficult to say WHAT OP needs.
Thanks for your reply, I wonder if I can use a high pass filter so the square waveform can be passed better?
BTW, do you also have any ideas for the question below? Thanks!
https://www.edaboard.com/threads/the-input-reference-noise-voltage-is-larger-than-vdd.412442/
A high pass filter will pass a square wave better than a low pass, but it won't do anything to reduce high frequency noise. What, exactly, are you trying to accomplish? It's enormously unclear.
The input is a 500 kHz square wave with at least 50 MHz bandwidth
Your Op Amp lacks the bandwidth to pass this signal even with a partial differentiator arrangement and does not meet your expectations and degrades the signal. So it is not clear why you are doing this.
Even a logic gate would work better to buffer a square wave.
We have no idea what you want to do but this is not likely to be improved unless you wanted a sine wave RC filter at 500 KHz or any odd harmonic..
LaTeX Commands Quick-Menu:
