TO220 heatsink with thick base and fins?
cupoftea
Advanced Member level 6
What's exactly the available room? Can't you use a heatsink like Fischer SK469 or SK437
36 °C/W, TO-220, 25 mm, 25 mm, 6.5 mm​
50 °C/W, TO-220, 13.2 mm, 12.7 mm, 19.1 mm​
15 °C/W, SOT-32, TO-220, 25.4 mm, 13 mm, 30 mm​
14 °K/W ................. 16 mm, 16 mm, 50 mm
The Rth specs assume lots of space around the heatsink, which you do not appear to have, so do not under-design it. Parallel heatsinks are not like parallel resistors for Rth.
But my guess (?) is you are just trying to add mass to absorb power-on transient.
WAKEFIELD THERMAL 274-2AB
Thanks, we are indeed space constrained.
The SK 469 35 STS looks best, as we have 36mm height available
The PCB is vertical mounted so the verticality of the heatsink will be violated, and it will be horizontal.
Then for best heatsink operation you need to mount the heat sink flat on the PCB so the fins run vertically.
LaTeX Commands Quick-Menu:
