Shunt measurement of CT measurement
FreshmanNewbie
Full Member level 6
Which the better option for accuracy and cost?
I have a charger board to EV. For measurement, I'd like to have good accuracy as well as cost.
So, in that case, should I go ahead for current measurement with CT or shunt measurement with resistor?
I want to go on vacation. I want to go on an island. Good quality as well as cost. So in this case should I go by airplane or by ship?
This is not meant rude. I tried to give exatly the same informations for my vacation as you gave for your application.
Honestly:
Without any informations about quality, volume, cost, signal current, voltage, frequency range ....... how should we be able to give good feedback?
Give good information .. to get good feedback.
I´ve done applications for AC 2000V / 3000A: for sure I used a CT .. simply because of isolation. I could have used a simple CT, but I needed to use the one with "magnetic compensation" to also get DC residual information.
I´ve also done applications using resistors .. because of small size.
We expect specs for current and BW with a budget. If you have none. A length of cable feed can be your shunt with an isolated chopper INA and shielded pair. For low ESL it can be a folded length of cable and try to get 1 mV resolution 20 dB SNR. For ease get a CT and compare. See if you can prevent the EMI interference in your properly biased INA sense STP cable with DC supplied on a connector. Then compare spectral density and accuracy.
Nothing is cheap or accurate until you have specs and tools to compare with experience. Make a test plan.
Some expressions in Morse code allow only the ones who know the subject to respond; 'weeding out' who do not or unsure. I do not know if CT is center tap, or charging transformer, or computerized tomography. Why some posters assume everyone receives their telepathy ? Is it that hard to type ?
I used the shunt method to measure 10kA
That´s impressive.
10kA is pulsed I guess.
What´s not clear. If there is 100uV@10A, then it´s 100mV@10kA, so 1kW of power dissipation. (plus all the wiring and connections around)
And copper has a rather huge thermal drift (temperature coefficient) ...
I guess I never had the idea to do 10kA measurement using a shunt. But seems to work.
Wikipedia disambiguation also lists current transformer. The latest confusion about AC or DC measurement however substantiates your doubt. More likely the original poster is asking for a DC capable current transducer (hall sensor based). Better to tell unequivocally what you mean.
LaTeX Commands Quick-Menu:
