Interesting method to catch oscilations
yefj
Hello,in the attached video they catch oscilation using loop antenna, few questions:
1.how can we distinguish oscilations from noise with this loop antenna method.
2.Antenna works on fringing fields,so how exactly this they create this "antenna"
they took a wire made circles and tied one end to center and other to the shielding?
or both ends connected to the central pin?
Thanks.
all it does: it picks up magnetic RF field.
It does not destinguish between signal or noise. It´s the job of the user and the measurement device (scope / spectrum analyzer...)
The above might be useful.
Regards, Dana.
These are all near-field probes. you can also short a 10:1 probe with ground clip and plug into spectrum analyzer to look at noise > 20 MHz or coax and magnet wire for higher f.
E-fields will be mutually coupled and B fields enclosed by loop.
Reactions: yefj
    yefj
Just be sure your portion of ground lead alligator clip cannot
contact powered up parts, hence damage/destroy them.
EMI probes generally well insulated for this problem.
Regards, Dana.
LaTeX Commands Quick-Menu:
