Write vectors to a file in Matlab?
davyzhu
Advanced Member level 1
oriental
Hello all,
How to Write vectors to a file in Matlab? And read from the file? The easiest way?
For example, A=[1 3 5 7 9],B=[2 7 6 8 9 10 11 12],C= ...and I want to write/read these vectors to a file, thanks!
Regards,
Davy
I think the easiest way is use the "load" and "save" commands
To save a vector x and a vector y to a file names "Myfile" do the following:
save 'Myfile' x y
Note that you can save any number of vectors to the same file, just separate them by a space
To load those vectors into workspace use:
load 'Myfile' x y
Hope this is useful
    davyzhu
use fprintf
example:
x = 0:.1:1; y = [x; exp(x)];
fid = fopen('exp.txt','w'); %file's name mode write
fprintf(fid,'%6.2f %12.8f\n',y); %write in file
fclose(fid);
