MOS resistor switch for controlling capacitor
Junus2012
Italy
I am using MOS switch for controlling bank of capacitors.
The capacitor bank is a binary weighted array start from 50 fF, 100fF, 200 fF, 400 fF, 80 fF, 1.6 pF,
These capacitor represent the compensation capacitor for my op-amp toward bulding programmable bandwidth amplifier.
Coming to the switch size, what is the rule for sizing it?
I have read that ratio should be high enough to achieve the current phase of a capacitor in the range of -90 ° plus minus 1°, is that true? and how can I simulate it?
this means for every capacitor value there must be different size switch depending on the controlled capacitor size
Thank you in advance for your help
You can run the AC analysis simulation in P-SPICE. This will calculate the frequency response of the circuit. This will allow you to observe the phase shift of the current through the capacitor bank. During the simulation process, you can vary the dimensions of the MOS switch, such as the width-to-length ratio (W/L), to determine its optimal size.
    Junus2012
You can have a "switch and capacitor" unit for say 50fF.
Then you use multiples of them to get the rest of them.
This way all the RC time constants remain the same since the the switches come in parallel and the capacitors add up.
The above is basically a capacitor DAC. You can find structures of them online in the context of CAPDAC SAR ADCs.
With regards to the sizing, you just have to ensure that the worst case switch resistance does not screw up your compensation by too much. That is, you are still stable within your specifications.
Of course worst case switch resistance would be across PVT+MC
    Junus2012
thanks for the reply,
let start with the small capacitor unit of 50 fF.
Now you suggested that MOS switch resistor should be considered, I agree. However, in order to reduce the switch resistor, this requires to increase the switch ratio, which in turn increase its parasatic capacitor and might be the parasitic of the switch will be dominated over the unit capacitor.
