Junus2012
- Joined
- Jan 9, 2012
- Messages
- 1,552
- Helped
- 47
- Reputation
- 98
- Reaction score
- 53
- Trophy points
- 1,328
- Location
- Italy
- Activity points
- 15,235
I am trying to increase the speed of my opamp by increasing the gain bandwidth product. As it is known, the common approachs of increasing the gain bandwidth product (GBW) leads to decrease the amplifier gain, for example when increasing the biasing current or use shorter channel length. Hence what happened that I still receive the same GBW, it became a constant because GBW = f (-3 dB)XDC gain, so the increment in f (-3 dB) will be compensated by the drop of the DC gain.
Since the DC gain I have in my circuit is enough for my closed loop gain accuracy, I don't want to enhance the gain further for the sake of having larger GBW. This led me to the fact that the opamp speed should be evaluated with respect to f (- 3 dB), not to the GBW. On the other hand all op-amp data sheet present the value of GBW as a measure of their AC speed.
Note: I am assuming the opamp have no slew rate limitation.
I would like to have your discussion on this regard
Thank you in advance
