ElecDesigner
Member level 5
- Joined
- Jul 22, 2014
- Messages
- 94
- Helped
- 4
- Reputation
- 8
- Reaction score
- 5
- Trophy points
- 1,288
- Activity points
- 2,190
I'm looking to upgrade an existing product that is essentially based around charging one or more caps to HV (multi kV), and discharging (through a thyristor) into a low impedance RL load (typically impedance around 1 ohm). The discharge pulse is very high current (as you can imagine) and lasts a few 100us.
In practice the Thyristor is actually several devices in parallel and series to handle the voltage, current, dI/dt etc. Series inductors, parallel R and RC etc are used to force the necessary sharing. I haven't shown all these to simplify the diagram. Gate drives (again not shown) are isolated and coincident. - All works fine (long proven record).
Now I want to upgrade the solution to allow the option of (optionally) discharging multiple capacitors into the same load using essentially repeats of the capacitor and Thyristor setup shown.
I.E. the Thyristor cathodes (bottom row) will be connected together but not all banks will necessarily fire at the same time (or at all). Capacitors in the banks that are unfired may or may not be charged. This leads to two questions.
1. The above will require the reverse diodes will need to be omitted to allow reverse voltage to develop (if necessary) across the unfired banks. Can anyone think of a problem removing those (not sure what their use is).
2. Is there a fundamental issue with a high speed change in voltage across the unfired banks I.e. either from 5kV to 0kV developed across the unfired Thyristors (cap charged) or 0kV to -5kV (cap uncharged). I would have thought any dV/dT issues wouldn't be an issue as the voltage is reversing but not sure what else could go wrong.
