inklen
Full Member level 1
Hi!
I build this FM transmitter using MAX2606 but since I'm still new to electronics, I'm not even sure how to check if it works... :/
Here's the schematic:
1) I'm not sure the schematic is ok. I took it from the web somewhere and slightly changed (well, according to my level of knowledge)
2) I built it and checked all the traces, all the connections on the PCB - seems to be ok. When I turn it on, the only thing I can do is to measure voltages on the IC, etc. That also works. As I don't have anything except my Fluke, is there anything I could do to understand if it works or not?
I tried to find any presence of transmission with RTLSDR but no, can't find anything in the range.
Please help me out here.
PS. What's interesting I don't seem to find a good book on radio and FM radio in particular. I've read about types of modulation and some basic stuff. Then I run into something called "pre-emphasis" and got lost. So I'd appreciate any suggestions on the radio books.
