Ironlord
Member level 3
I have developed the following code to calculate a CRC.
I am passing it a Start signal and a Frame, which is 12-bits of data. The CRC works picking up the message in Nibbles, so as I have 12-bits, I will divide it into 3 Nibbles.
I am trying to simulate this code on ModelSim, but when I put the Start signal from '0' to '1' it fails. I still don't know what am I doing wrong. Somebody could give me a hint?
The problem is on the sentence "tmpCRC<=crcLookup(miNum);"
Thanks in advance.
Thanks in advance.
C-like:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
use ieee.std_logic_arith;
ENTITY getCRC IS
PORT(
Start : in std_logic;
Frame : in std_logic_vector (11 downto 0);
Done : out std_logic;
CRC : out std_logic_vector (3 downto 0)
END getCRC;
ARCHITECTURE a OF getCRC IS
--CRC Look-Up Table:
type TABLE is array (1 to 16) of std_logic_vector(3 downto 0);
constant crcLookup : TABLE := (x"0",x"D",x"7",x"A",x"E",x"3",x"9",x"4",x"1",x"C",x"6",x"B",x"F",x"2",x"8",x"5");
signal frameTmp : std_logic_vector (11 downto 0); --Copy of Frame input into internal signal
signal index : integer range 0 to 3 :=0;
signal j : integer range 0 to 11 :=11;
signal status : std_logic :='0';
signal miNum : integer range 1 to 16:=5;
signal tmpCRC : std_logic_vector (3 downto 0):="0101"; --Temporal CRC calculation.
begin
frameTmp <= Frame;
process(Start)
begin
if(Start='1' and status='0')then
while(index<3)loop
miNum<=to_integer(unsigned(std_logic_vector(tmpCRC)));
tmpCRC<=(tmpCRC xor frameTmp(j downto j-3)) and x"F";
if(j>3)then
j<=j-4;
end if;
index<=index+1;
end loop;
status<='1';
j<=11;
index<=0;
end if;
end process;
--Outputs--
Done <= status;
--CRC <= tmpCRC;
end a;
