promach
I enabled Dynamic Phase Shift Ports inside ISE clocking wizard coregen, however I have the following issues about unsupported frequencies marked as XXX in the table:
100MHz, 200MHz, 300MHz, 400MHz, 500MHz are all not supported when Dynamic Phase Shift is enabled.
Note: I am using 50MHz source clock
