risingcurrent
Newbie level 5
- Joined
- Jan 20, 2005
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 104
Hi guys
i need help with a 555 timer circuit that i am trying to design , the 555 timer is used as a LED flasher , it has three user controlled settings Low ,Medium and High.
Low denotes a time interval of 60 Min,Medium of 24 Min,High of 10 Min , the problem is i want the circuit also to compensate for the time when the user changes the setting , will try to explain what i mean by compensate .
Suppose the circuit is in Low which means 60 Min and a time period of 20 Min has elapsed and suppose the user changes the setting to Medium which means 24 Min ,since already 20 Min has elapsed , the circuit should take only 4 additional minutes to turn on.
how can the circuit remember the previous time elapsed without a lot of additonal components , just with a basic knowledge of it i thought since the capacitor already has charged/discharged some amount of charge when the resistance is changed the remainder charge would set the time accordingly .
please correct me if i am wrong and all suggestions are welcome.
risingcurrent
risingcurrent
