T
treez
Say you've got a product to go for radiated immunity testing, and it is mains powered, and comprises a metal box containing a 60W offline SMPS, and a tx/rx module. The metal box feeds 12 metres of coaxial cable to a straight antenna of length some 10's of cm.
The metal box also feeds a 12v isolated cable (screened) to an open metal box which contains a 10W battery charger.
How do you get it to pass radiated immunity at 10V/m?
After all, the product has an antenna, which is designed to pick up radiation and feed it to its receiver....so its bound to fail?
