mtwieg
Advanced Member level 6
I don't see why this would make emissions worse, not better. It really depends on layout. If a snubber is properly designed, then it provides a low impedance path for high frequency currents, but in doing so it should divert those high frequency currents from other components which would radiate more.A…..Adding an RC snubber from switching node to ground at the Buck SMPS may well have a good effect. However, the sudden discharge of the snubber capacitor simply means there will be another radiated emissions problem, but above 1GHz, where formal testing does not take place?
Then damp your filter?B…….If we use common mode chokes with Y capacitors to the chassis, then any failure peaks that we may get are just as likely to be coming from resonance in the common mode LC filter, as from genuine noise emissions? As such, tweaking the Y capacitor value to try and bring peaks down is likely to be futile, as it will just mean getting a resonant peak at a different frequency?
Because EMC stuff is highly anecdotal, and solutions can end up being very specific to a product/system. You can't just copy paste someone else's input filter design and expect it to work in another application. In the end the empirical results are what matter.G.......Why on the entire web are their No forums, or sub-forums, for people to ask questions about EMC testing of products?....is it because the actions taken to get kit through EMC testing is the deepest secret of any company?
Again, if you have a specific problem you're trying to solve, then you're better off just trying all these options in the lab rather than asking people on the internet.C……
D…….
E……
F….
