seqc1712
hfss rcs airbox
Hello guys,
I have big problem with simulation accuracy of HFSS. I simulate an electrical small antenna(meander line antenne) with radiation boundary of a airbox. The results depend too much on dimension of the the airbox, although the mesh is fine and the convergence is also okay. The HFSS-modell has been attached, run the parameter sweep you will see the different results.
Has anyone the similary problem with HFSS? or any HFSS professional knows the reason. Tips and advices are appreciated!
Hello guys,
