MT8870 datasheet and circuit example
arash_micro
Member level 5
Member level 5
Hi all
MT8870 returns the caller ID or shows the number that
has pressed.
THanks
caller id mt8870
arash_micro said:
Hi all
has pressed.
THanks
depend of contry
different contry has different system for caller ID
and MT8870 is a DTMF-tone reciver circurits
- is working in Sweden but i don't know if working
on other contry.
MT8880 can recive and sending out DTMF-tone.
inbuilt caller id in mt8870
Thanks alot
have you a sample of caller id using MT8880
mt8870 + caller id + dtmf
arash_micro said:
Thanks alot
read Mitel:s data chart for this circurit...
mt8870 caller id data sheet
try this
8870 data sheet and circuit example
caller id con mt8870
Hi all
I was make my caller id with MT8870.
when i push my phone numbers ,the number will apear on the lcd display
but when my friend phones the number doesn't come.
Even the Std pin doesn't flash.
What configuration i must use for MT8870.
caller id with mt8870
It's not problem with your circuit as you are getting the numbers you type on your phone on display. The problem lies in either your Telephone Company is not sending the Caller ID info or you connected the caller ID module to the line after hook switch. Either case please check in this way, first confirm the Caller ID format in your area is DTMF & not FSK. Then check the Telephone Company is providing you the CallerID infromation. Hope this helps..
