Need help for two analog inputs to PIC
tufan
Junior Member level 3
HELLO
FRIENDS I need your help
Can you do the following circuit with u
controller.?
pic has two DC analog inputs
I have to use two adc I think
and the controller will make the following algebric
manipulation:
(Input1-ınput2)/( Input1+Input2)
now I Thougth to use 16f877
However I dont know how to code them ADC is a NEED BUT I need two output or a mux is enough?Do you have any advices to me ?
regards
Re: NEED HELP FOR TWO ANALOG INPUTS TO PIC
tufan said:
HELLO
controller.?
manipulation:
regards
1. Do not post your title in all caps.
2. Another I think analog inputs are used as comparators only (correct me here if I am wrong).
3. You need either a differential amplifier and feed the result to the ADC of the micro or if the rail of your analog input is from 0 to 5V, I think you can feed it directly to the ADC.
4. Do not forget to use signal conditioners if your rails are above 5V or you have a negative rail.
What kind of signal conditionar do you mean?
else
I won't give anolog inputs to directlı uc but of course to ADC
and inputs maybe 10 volts
Thanks for adjusting your title, you will inject a 10V analog signal to PIC? I do not know if the ADC can support that but you can check the datasheet.
Signal conditioners are like pre-amps, buffers or level converter, they convert the input signal to an acceptable level by the microcontroller or any circuit.
    tufan
Dear glenjoy
I want to ask :can I use only one uc which has one ADC (for two inputs)?
and doyou have any idea about the codes in C for Adc and
(Input1-ınput2)/( Input1+Input2) manipulation?
thanks
Added after 19 minutes:
sizce bugun yetisir mi?
Dear friends
Do you think that I can solve this problem within a 3 hours?
Have you got any offers?
tufan said:
Dear glenjoy
thanks
Dear friends
Do you want to outsource it? PM me.
Can not you do?
I think it is easy for you
so I said that
If you can help I need it much
Yes I can do it, just PM me your requirements and if you yahoo messenger, you can PM me your email address.
