Zak28
Advanced Member level 2
Can the dwell time and period on the primary side be any duration so long as it abides by the maximum peak current?
https://www.summitracing.com/parts/pnx-d3070
Manufacturer's Part Number:D3070
Primary Resistance:0.350 ohms
Coil Internal Construction:Epoxy
Maximum Voltage:50,000 V
Turns Ratio:85:1
Secondary Resistance:8.30K ohms
Inductance:2.80 mH
Peak Current:7.9 amps
Spark Duration:1.5 mS
