eagle1109
Full Member level 6
- Joined
- Nov 20, 2014
- Messages
- 393
- Helped
- 4
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Saudi Arabia
- Activity points
- 5,956
I was searching on Aliexpress for dual power supply for my electronics collection. And I ran by these boards.
They actually receive AC input at lower voltages, which I think not very easy to use because I need AC source at low voltage, which means I need another stage to lower the mains voltage for this module.
The following two links are for power supplies that receive AC input and provide +/- dual variable voltages which are very nice except they need AC input at low range.
https://www.aliexpress.com/item/New-Assembled-LM317-LM337-Dual-Power-Adjustable-Regulated-Power-Supply-Board/32346362104.html?spm=2114.10010108.1000014.2.165565467WuaLO&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.112237.000000000000000&scm_id=1007.13338.112237.000000000000000&scm-url=1007.13338.112237.000000000000000&pvid=0f0928e5-df87-431d-a8a5-42318eeaa9dd
https://www.aliexpress.com/item/LM317-LM337-1-5V-37V-Adjustable-Dual-Voltage-Regulator-Power-Supply-Module/32515637290.html?spm=2114.search0104.3.8.29222e4bSYuXlH&ws_ab_test=searchweb0_0,searchweb201602_8_10065_10870_10068_319_10867_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536_10902,searchweb201603_6,ppcSwitch_0&algo_expid=8557a30c-fde5-4cec-af74-26a9c89e9cb4-1&algo_pvid=8557a30c-fde5-4cec-af74-26a9c89e9cb4&transAbTest=ae803_3
These two are much better in my opinion, because they are DC/DC converters which means I just need to plug a DC power adapter and then I get +/- voltages:
This one has 1A output.
https://www.aliexpress.com/item/LM317-LM337-negative-dual-power-adjustable-power-supply-board-Electronic-Component/32863878979.html?spm=2114.10010108.1000014.3.4e3e3bbfJadd6f&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.112237.000000000000000&scm_id=1007.13338.112237.000000000000000&scm-url=1007.13338.112237.000000000000000&pvid=3b94f08d-354c-4b8f-b1d4-8dc24aad4972
I also like this one, it has much power 3A for +ve rail and 2A for -ve rail.
What do you think guys about these boards? Are there better options?
What do I need if I want to start designing similar boards to serve my bench applications?
