CHL
Member level 3
Hello
I wonder if MOSFETs in a comparator should be in saturation region or not.
Let's say an input out of two comparator inputs is fixed at a reference voltage and the other input varies. We can check the gain and bandwidth by putting the reference voltage to the input. In this case, should I make all the TRs be in saturation? or only bias TRs?
