Microcontroller <-> Profibus DP
Moof
Full Member level 2
Full Member level 2
Argentina
profibus dp specification
Anyone has something about conecting a microcontoller to a profibus DP?.
profibus microcontroller
Profibus DP can transfer up tp 12Mb/s, so I think that you must have very very very fast mcu to do all things. Siemens have CP for Profibus (Communication processor), which do only profibus protocol, so think again if you want to implement this protocol on mcu.
Profibus is RS485 by hardware, but I don't know where you can find protocol details.
Best regards,
Mr.Cube
microcontroller profibus
Speed is not a big problem, i can use a dspic or similar dsp+microntroller or even a dsp, that are really fast. The problem is, like you said, the protocol!!.
I need the protocol.
spc3 profibus
As I know owner of this protocol is Siemens and 'couse of that I think that is very hard to find protocol definiton.
Mr.Cube
profibus dp protocol specification
Hi!
Here is Profibus DP specification. I'm not sure that this is last version, but anyway I think it may help you.
I have some more PDFs about Profibus, contact me if you need more info.
Part 1 General Description of the Normative Parts 5
Part 2 Physical Layer Specification and Service Definition 13
Part 3 Data Link Layer Service Definition 49
Part 4 Data Link Layer Protocol Specification 97
(protocol is specified together with services in 3-2)
Part 5 Application Layer Service Definition 139
Part 6 Application Layer Protocol Specification 315
Part 7 Network Management 591
Part 8 User Specifications 687
Part 9 Physical Layer and Data Link Layer for Process Automation 885
Reactions: amrstaha
    Moof
    amrstaha
profibus-dp specification
Dear Akorostel,
do you have the PDF with the protocol specifications for the ProfiBus ?
If you have, would you be so kind to share it ?
Thanks for it
Antonio Sergio Sena
profibus protocol specification
Siemens has a firmware for 8051 micros from Siemens/Infineon, we have done some projects with a C517 and the siemens SPC3 chip, it is still working very well...
Regards...
profibus dp specifications
Dear Mr_Programmer,
that firmware is in Assembly or C ?
Do you mind to share it ?
I am planning to implement a ProfiBus comm on my systems, and that would be vey handy.
Antonio Sergio Sena
dspic profibus
Hi asena,
the firmware is in C and was compiled with 8051 Keil Compiler...
But the firmware itself is licensed, a part you can buy from Siemens / Infineon
Regards...
profibus dspic
Dear Mr_Programmer,
thanks for the follow up.
I'll chase Siemens for that code then.
thanks
Antonio Sergio Sena
profibus mikrocontroller
Dear Asena,
You can also try to use the VPC3+C from company Profichip (www.profichip.com). It is compatible with the SPC3 from Siemens, but Profichip are much more accesible than Siemens. Furthermore you can order to Profichip free of cost samples.
From wich country are you? I' m from Barcelona (Spain)
Best Regards,
Ramon Maldonado
profibus datalink
we tried also the VPC3, but the behavior was different to the SPC3 so this chip wasn't accepted as second source for our project.
Regards...
