Zak28
Advanced Member level 2
I didn't check the series resistances.
But with a L1/L2 ratio of 30/300, I expect a coupling factor of sqrt(300/30)...which is about 3.16.
Resistances are 1 ohm per coil and it does not matter what values the coils are, even extremely far in inductance still yeilds lower voltage on secondary.
It matters well. Problem is that you apparently never calculated the 20 Hz reactance of your transformer magnetizing inductance settings, otherwise you won't use ridiculous small µH values. Try again with 30 and 300H.
