For harvesting you use a receive antenna, not a transmitter antenna although the two are basically the same.
Is it possible to use a mobile phone's Bluetooth as a transmitter and a patch antenna at 2.4 GHz as a receiver for RF Energy harvesting so that a considerable amount of voltage is received at the output ?
Please help me thanks in advance
What should ideally be used as the transmitte ?
