mickey123
Member level 5
Please can anyone tell me how I can simulate a CubeSat with the frame and antenna in CST and if there are any resources or examples available ?
Please help me thanks in advance
1. Is it that the ground plane of the patch antenna and the metal of the frame get added up to give different results?
2. How are the patch antenna and frame connected....I got a CAD file of the frame which is imported into CST and placed the antenna on one of its sides and simulated it...the results are different...can you please tell me whether this is the right method?
when i say ground plane of frame does not affect the antenna performance, i assume there is proper space between the antenna and the frame of the CubeSat.
How do we fix the Antenna to the frame ?
what is used to fix it to the frame ?
