[CST] How to simulate an ISS (impedance standard substrate)
Vsl
Newbie level 3
Newbie level 3
[CST] How to simulate an ISS ( impedance standard substrate )
Dear all,
I'm tryng to simulate a CST structure like the one you can see in the picture. The structure represent the Open standard realized with alumina on a silicon substrate.
The three pads represents the landing pads of a typical ground-signal-ground probe.
The problem is how to simulate them. Do you suggest to use a waveguide port ( as shown in the second picture ) or three lumped port, one on each pad?
Thank you in advance,
V.M.
Re: [CST] How to simulate an ISS ( impedance standard substrate )
Vsl,
Per the CST manual, if there are 3 or more conductors in proximity it is recommended that you use a multipin waveguide port. I would recommend reading this section of the manual, it isn't that dense. It is easy to find by clicking on "help" while you are in the waveguide port creation menu.
Reactions: Vsl
    Vsl
