Show me ADS netlist.When i name VD=Vo and simulate it
The Vo(dB) becomes -1
Hi
DC operation points are calculated in all analyses of ADSsim.since you are not doing DC simulation, that is AC result.
ADD simulation-DC to see DC result.
No.Yeah that is true.
But if you want to Annotate DC solution you need DC simulation.
No.
ADSsim does not require DC Analysis.
On the other hand, Cadence Spectre requires DC Analysis.
It seems you are very beginner regarding simulator.Do you know how to see bias points on circuit ?
I am talking about Annotate DC solution and it needs DC simulation.
Wrong.ADSsim does not require DC analysis but for "Annotate DC solution" you MUST do DC analysis.
Simply you are offering unnecessary informations.I did not say your simulation does not work or does not do DC simulation,
I offered him to do a separate DC analysis in order to observe his problem better;
however, problem was other thing.
I realized he is talking about bias and he is doing AC simulation,
I offered him to use only DC simulation to focus on biasing
otherwise I never said for AC simulation you need DC analysis as well.
I think you don't set small signal amplitude for "VtSine".
If you can not set small signal amplitude for "VtSine", use "V1_tone" or "V_AC" instead of "VtSine".
Note "VtSine", "V1_tone" and "V_AC" are all same component "V_Source" in netlist.
Just they are different regarding parameters.
I don't think so.I am not a beginner I designed many ICs with ADS.
Wrong.Probably I forgot about that
since I always work with Harmonic balance simulations
and sometimes in those simulations if you dont put DC analysis you wont see bias point.
Surely see ADS netlist.for AC simulation you need freq domain source not vtsine.
Hi
How can i bias a nmos 2v in 0.18um in ads?View attachment 140155
How can i bias a nmos 2v in 0.18um ... ?
V(R1) = (V_DC - Vdsat)/2 = 0.5V
Vds(X1) = (V_DC - Vdsat)/2 + Vdsat = (V_DC + Vdsat)/2 = 1.3V
I(R1) = Ids(X1) = V(R1)/R1 = 0.5mA
Hi
% adssim -h V_Source
V_Source [:Name] p n <parameter=value> ... ; (device)
Parameters:
Vdc (V) smorr DC voltage.
Vac (V) smorc AC voltage.
V[,,] (V) smorc Large signal voltage at a given harmonic.
V_All smorc Large signal voltage at all harmonics.
V_USB[,,] (V) smo-c Small signal voltage at a given upper sideband.
V_LSB[,,] (V) smo-c Small signal voltage at a given lower sideband.
FundIndex sm--i Single fundamental index for this source.
V_Noise (V) smorr Noise Voltage.
PhaseNoise (dB) smo-r Phase noise as a function of offset frequency.
V_Tran (V) smorr Transient voltage.
HarmList (V) smo-c Array of large signal harmonics.
Freq (Hz) smo-r Actual n'th frequency value.
SaveCurrent s--rb Send source current to rawfile.
Tnom (deg C) smorr Nominal temperature in degrees Celsisus.
TC1 (1/deg C) smorr Linear temperature coefficient; per degree Celsius.
TC2 (1/(deg C)^2) smorr Temperature coefficient; per degree Celsius squared.
Type s--rs Source Type (e.g. V_DC for DC source) genereated by PDE..
Instance DC operating point parameters:
Is (A) ---rr Current.
Power (W) ---rr DC power dissipated.
Vs (V) ---rr Voltage.
You can not understand my following append.How can you do AC simulation with putting vtsine in this schematic with constant frequency ?
