hobbyiclearner
Full Member level 2
My 3 year old desktop SMPS stopped working properly ie. it was able to supply power to motherboard but not to HDD and DVD writer. When I connected a brand new SMPS, the system is working fine. So I am guessing that the components have aged.
While trying to debug it, when I switched on the SMPS, all the DC voltages were getting generated (+5, +12, +3.3, -12). Since the SMPS was not able to supply to all the load, my guess is that the current delivered from the SMPS to the load is less than the max. limit. My question is how do I check the max. DC output current of the SMPS? For eg. In case of +5v, the max DC current is 29A. So basically the load would be practically nothing. Can I simply insert the terminals of a multimeter in between the terminals of +5v supply to check the current delivered (I am preferring to ask before risking with the SMPS).
Thanks,
Hobbyiclearner
Thanks,
Hobbyiclearner
