venkates2218
Full Member level 6
In this circuit this is an LED connected with controller and push button also....
The LED will blink in different time interval...Ex.10sec to 200 secs.
And the LED should on when the push button is pressed means also...
My doubt is while running the LED from controller during this time if the switch is pressed means what will happen in TIP125..?
When push button is pressed more than 2seconds means the output from controller will turned off(I didn't mention in schematic)....
I this while is their any damage will occur in TIP125 or controller..?
