dursun
Junior Member level 3
fractal antenna in hfss
I wonder if you have simulated fractal antennas using HFSS. At the beginning I wanted to simulate some antennas described in articles, but unfortunately my result are different from those presented (which were simulated with another software). Therefore I had to switch to ie3d but it is very time and memory consuming tool. Have anyone came across this problem with HFSS?? Or maybe I am making some mistake in HFSS??
The attachement is my HFSS implementation of the antenna described in IEEE Transactions on Antennas and Propagation, vol 52, no.10, October 2004 pp2571-2579 "Analysis of a Modified Sierpinski Gasket Monopole Antenna Printed on Dual Band Wireless Devices" by Tsachtsiris,Soras,Karaboikis,Makios. If you have came across the same problem or could take a look at the project I would be very gratefull. I can e-mail the article in pdf if anyone would like to compare the project.
Best regards
Ania
Best regards
Ania
