promach
![Advanced Member level 4](/styles/images/ranks/hlevel1.gif)
anyone could relate the restoring part of https://paste2.org/7MUm29FL to https://en.wikipedia.org/wiki/Division_algorithm#Restoring_division ?
1) For lines 21 and 22, sub_out[16] is '1' if the subtraction overflowed (became negative), but WHY {reg_r[14:0],reg_q[31]} when the subtraction result is negative, and WHY sub_out[15:0] when it is otherwise ?
2) For line 38, what does reg_q <= {reg_q[30:0],~sub_out[16]}; trying to achieve ?
[syntax=verilog]
The Verilog HDL code example is from the book
Computer Principles and Design in Verilog HDL
by Yamin Li, published by A JOHN WILEY & SONS
module div_restoring (a,b,start,clk,clrn,q,r,busy,ready,count);
input [31:0] a; // dividend
input [15:0] b; // divisor
input start; // start
input clk, clrn; // clk,reset
output [31:0] q; // quotient
output [15:0] r; // remainder
output reg busy; // busy
output reg ready; // ready
output [4:0] count; // counter
reg [31:0] reg_q;
reg [15:0] reg_r;
reg [15:0] reg_b;
reg [4:0] count;
wire [16:0] sub_out = {reg_r,reg_q[31]} - {1'b0,reg_b}; // sub
wire [15:0] mux_out = sub_out[16]? // restoring
{reg_r[14:0],reg_q[31]} : sub_out[15:0]; // or not
assign q = reg_q;
assign r = reg_r;
always @ (posedge clk or negedge clrn) begin
if (!clrn) begin
busy <= 0;
ready <= 0;
end else begin
if (start) begin
reg_q <= a; // load a
reg_b <= b; // load b
reg_r <= 0;
busy <= 1;
ready <= 0;
count <= 0;
end else if (busy) begin
reg_q <= {reg_q[30:0],~sub_out[16]}; // << 1
reg_r <= mux_out;
count <= count + 5'b1; // counter++
if (count == 5'h1f) begin // finished
busy <= 0;
ready <= 1; // q,r ready
end
end
end
end
endmodule
[/syntax]
