[SOLVED] Reference voltage pin for Kinetis L03 (MKL03Z8VFG4)
mrinalmani
Advanced Member level 1
Delhi, India
Hi!
My application requires sampling of three analogue lines and transmitting the results via serial line.
I am thinking to use NXP Kinetis L03 series - MKL03Z8VFG4.
But I am not sure about the analogue reference voltage pin. The datasheet says (on page number 34): "For packages without dedicated VREFH and VREFL pins, VREFH is internally tied to VDDA, and VREFL is internally tied to VSSA".
The 16-pin package does not have dedicated VREFH and VREFL. So the reference pin should be internally tied to VDDA. However the package does not even have a VDDA pin. As far as power is concerned, there are only two pins i.e. VDD and VSS.
What does this mean? Does it mean that VDDA and VDD are the same? The datasheet also mentions that there is a 1.2V on chip voltage reference. How to use this reference?
Anyone with experience with Kinetis L series please help...
Thank you!
I'm not experience with NXP Kinetis, but it's a usual Cortex-M0+ micro.
VDDA and VSSA usually mean analog voltage supply for the systems with separate analog and digital power supply. If you don't split analog and digital parts, you can use these pins as usual VDD and VSS.
As for 1.2V reference, the reference manual **broken link removed** p.449 contains info about VREF and how to use it.
Thanks for the reply!
The reference manual solved the purpose.
