How does this function work for displaying string in lcd?
94d33m
Junior Member level 2
lcd_string("welcome");
void lcd_string(unsigned char *p)
     while(*p!=0)
           lcd_char(*p++);
void lcd_char(unsigned char cha)
       lcd_data_port=cha;
       rs=1;
       rw=0;
       en=1;
      delay(10);
      en=0;
How does the function lcd_string work?
lcd_char() puts a single character code on the LCD data lines then operates the control lines to write it to the LCD module. If the delay(10); is 10mS it can be considerably shortened!
lcd_string() takes the string and keeps callling lcd_char, passing it one character from the string at a time until it finds a NUL (zero) character. Strings in 'C' are stored with a NUL at their end so it uses it as a marker to say 'no more' after all the characters have been displayed.
Reactions: 94d33m
    94d33m
and does lcd_char(*p++) mean it sends the value to the function first then increases its value ??
Yes, by C syntax rules. That's why we call it a postfix increment operator.
Reactions: 94d33m
    94d33m
To be more clear, it sends the character (dereferenced by the pointer 'p') and then increments the pointer 'p' (post-incrementing), after this 'p' points to the next character.
Reactions: 94d33m
    94d33m
