kathmandu
Full Member level 5
I want to use a PFC chip (FAN4800) to build a battery charger. Unlike the typical application, I'm using a low voltage input (30VAC) and I want to control (set/limit) the output current.
It might be enough to use a CT sensor on the output and feed its output to the PFC chip voltage feedback pin?
Also, could it be better to put another inductor in series with the load to get a smoother current and to avoid a large output capacitor bank?
