amplification factor of Amplify and forward protocol
hmayna
Newbie level 6
Newbie level 6
Hi all,
in AF protocol the relay multiply the received signal from the source by an amplification factor
β=sqrt(P/(N0+P|hsr|²)
where P is the transmitted power,hsr is the channel 's vector between source and relay,
my question is about how to calculate |hsr|² if we have hsr=randn(1,N)+j*randn(1,N) i other way hsrr is a N complex number.
In MATLAB you can write
abs(hsr)^2
Reactions: hmayna
    hmayna
I forgot to mention that because hsr is a vector you need to use abs(hsr).^2 (with . preceding ^).
Reactions: hmayna
    hmayna
