Palpurul
Member level 3
Does input offset voltage of opamp reverses polarity with temprature change?
It's well known that input offset voltage of opamp changes with temprature. My question is, let us say we have +30uV offset voltage and let's assume noninverting input is higher than the inverting input. it's going to change with temprature with some spesific value. Can the polarity of the offset voltage change with temprature. To clarify with temprature change, can offset voltage be -30uV or some other negative voltage?
