Whats the difference between priority and normal encoders?
Haytham-Sief
Alexandria, Egypt
Encoders
What is the diffrence between the priority Encoder and the normal encoder ? Plzz if any one can reply I will be thankfull. Also give me the number of an encoder without priority.
Thnx
Re: Encoders
Thnx
Normal encoder gives equal priority to all inputs ..while priority encoder checks gives prirority to some inputs over others ... for example..
if (cond [0] == 1)
q <= 1;
else if (cond [1] == 1)
q <= cond [1];
else
q <= 0 ;
The h/w equailvalent will be such that cond[0] if top priority ..if it is one then it does not matter if cond[1] is 0 or 1 ... the implementation is usally in a layered mux condition.
Encoders
When you want to implement a priority encoder in VHDL/Verilog you use the if-else statement. The higher the priority the lower the delay. For normal encoders you use the case statement.
Re: Encoders
Thanx very much for ur help but plzzz I need more explaination , I'm not using VHDL I'm using hardware without controling I mean I cant conrol the priority of the encoder. Thnx alot
Re: Encoders
If you are using schematics then I uploaded you two pictures of a priority and a normal encoder examples.
In priority encoder x2 has the highest priority while x0 has the lowest one.
In parallel all have the same priority.
Hope it helps
Re: Encoders
It is very useful. Thanks for your sharing.
