RITESH KAKKAR
Banned
![Full Member level 5](/styles/images/ranks/flevel2.gif)
How to code what is algo of Navigation work in Embedded
1. Determining your current location - This can be done using a GPS module - would give you your current position in terms of latitude and longitudes.
Embedded engineer always work over work previously done by other. If you are embedded engineer your work starts from how to read data from GSM sensor and what you do with data.
Ok, what electrical and Electronic engineers do?
