[SOLVED] In vhdl, should for loop be always used inside process?
Anwesa Roy
In vhdl, should for loop be always used inside process? I want to design a program where I use for loop but without process, as some variables are turning into 0 as and when I am adding process.
A for loop is a procedural construct, so has to be used inside a process, function or procedure.
Why not post the code you're having trouble with.
For Loop must be used inside a procedure or process.
For Generate (which can also function as a loop) must be used outside.
Yes The code works fine after I have made changes. I had initially declared signals which were becoming zero after the program ran because signals are meant to be used for concurrent codes . After I changed signals into variables the variables modified properly. Here is the code:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.std_logic_signed.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity lms2 is
    Port (wr9,wi9,xr,xi,u : in STD_LOGIC_VECTOR (12 downto 0);
           --u : in integer;
           yr,yi,er,ei,wr8,wi8,zzz,sum1 : out STD_LOGIC_VECTOR (12 downto 0));
end lms2;
architecture Behavioral of lms2 is
--variable r,s : real range 0.0 to 15.0;
begin
process(wr9,wi9,u,xr,xi)--process also runs without the parameters,but it gives problems during simulation
--process(u,xr,xi)
variable wr : std_logic_vector(12 downto 0);
variable wi : std_logic_vector(12 downto 0);
--variable wr : std_logic_vector(4 downto 0) :="00010";
--variable wi : std_logic_vector(4 downto 0) :="00011";
--variable wr : std_logic_vector(4 downto 0) :=wr9;
--variable wi : std_logic_vector(4 downto 0) :=wi9;
variable yr1 : integer;
variable yi1 : integer;
variable er1 : integer;
variable ei1 : integer;
variable wr1 : integer;
variable wi1 : integer;
variable uu  : integer;
variable zz  : integer;
variable sum : integer:= 0;
begin
--process(xr,xi,u)
--bi <= to_integer(unsigned(k)) ;
--bj <= to_integer(unsigned(l)) ;
--bk <= bi*bj;
uu := to_integer(unsigned(u)) ;
wr := wr9;
wi := wi9;
for z in 0 to 1 loop
yr1 := to_integer(unsigned(wr))*to_integer(unsigned(xr))- to_integer(unsigned(wi))*to_integer(unsigned(xi));
yi1 := to_integer(unsigned(wr))*to_integer(unsigned(xi))+to_integer(unsigned(wi))*to_integer(unsigned(xr));
er1 := to_integer(unsigned(wr))*to_integer(unsigned(xr))-to_integer(unsigned(wi))*to_integer(unsigned(xi))-to_integer(unsigned(xr));
ei1 := to_integer(unsigned(wr))*to_integer(unsigned(xi))+to_integer(unsigned(wi))*to_integer(unsigned(xr))-to_integer(unsigned(xi));
wr1 :=uu*(to_integer(unsigned(xr))*to_integer(unsigned(wr))*to_integer(unsigned(xr))-to_integer(unsigned(xr))*to_integer(unsigned(wi))*to_integer(unsigned(xi))-to_integer(unsigned(xr))*to_integer(unsigned(xr))-to_integer(unsigned(xi))*to_integer(unsigned(wr))*to_integer(unsigned(xi))-to_integer(unsigned(xi))*to_integer(unsigned(wi))*to_integer(unsigned(xr))+to_integer(unsigned(xi))*to_integer(unsigned(xi))+to_integer(unsigned(wr)));
wi1 :=uu*(to_integer(unsigned(xr))*to_integer(unsigned(wr))*to_integer(unsigned(xi))+to_integer(unsigned(xr))*to_integer(unsigned(wi))*to_integer(unsigned(xr))-to_integer(unsigned(xr))*to_integer(unsigned(xi))+to_integer(unsigned(xi))*to_integer(unsigned(wr))*to_integer(unsigned(xr))-to_integer(unsigned(xi))*to_integer(unsigned(wi))*to_integer(unsigned(xi))-to_integer(unsigned(xi))*to_integer(unsigned(xr))+to_integer(unsigned(wi)));
--o <= std_logic_vector(to_unsigned(i,5));
wr := std_logic_vector(to_unsigned(wr1,13));
wi := std_logic_vector(to_unsigned(wi1,13));
zz :=z;
sum := sum+2;
yr <= std_logic_vector(to_unsigned(yr1,13));
yi <= std_logic_vector(to_unsigned(yi1,13));
er <= std_logic_vector(to_unsigned(er1,13));
ei <= std_logic_vector(to_unsigned(ei1,13));
wr8 <= wr;
wi8 <= wi;
zzz <= std_logic_vector(to_unsigned(zz,13));
sum1 <= std_logic_vector(to_unsigned(sum,13));
end loop;
end process;
You should really re-think your use of the various types in VHDL. It will help avoid having so many type conversion functions in your code. A plain old unsigned type for all the calculations would have been better.
Also using the non-IEEE non-standard library std_logic_signed should be avoided. I will avoid going into details as it has been beat on many times in the forum.
