PCB Silkscreen & Soldermask
tR|GG3rX
what is 'silkscreen' and 'solder mask' in PCB development?
does it effects the performance of a design?
You can find a lot of info about PCB's here:
best regards
PCB solder-mask is a layer of pcb that covers the top or bottom layer and protect the copper from etching, also at the soldering process it prevents making unwanted junctions.
PCB silk-screen is a layer on the board that is useful for mounting components, ordinary include the components name or value or name and version of the board.
silkscreen is just like labels.
    tR|GG3rX
Soldermask and silkscreen are applicable only for top and bottom layers.
SOLDERMASK-it is a nonconducting material poured on the top and bottom layers except on pads.
SILKSCREEN-it is text present on external layers to indicate the components
