PIC serial programming in hitech c
niranjan23
Member level 5
Member level 5
Hello!
I want to start programming on PIC16Fxx serial communication.
Im using MPLab with Hi-tech C compiler.
plz guide me for this. Any sample program to transmit character using serial com!!
Thanks!!
These tutorials are very good. The circuits & wiring are on Nigel's page. They were made for a parallel programmer. If you are using a serial programmer like Pickit, set MCLR configuration bit as MCLR and put a 10K ohm pullup resistor on that pin.
Nigel's tutorials in asm... **broken link removed**
Nigel's tutorials.. re-written in Hitech-C version 9.65. https://www.electro-tech-online.com/content/467-nigel-goodwin-s-tutorials-c.html
(HI-TECH C version 9.65 uses OPTION, HI-TECH C version 9.83 uses OPTION_REG and compacts programs better.)
