flote21
Advanced Member level 1
Hello folks!
I need to design a PCB driver with a FPGA to manage the control signals of several high power IGBT. These IGBTs are going to drive a lot of current (around 7000 Amp) and I need to do a robust PCB design.
I have been doing some EMC PCB designs for low power applications (maximum 3 Amp) and they are working very well. However I have never done a EMC PCB design for very high power application and I have been searching some guidelines:
https://www.st.com/st-web-ui/static...ical/document/application_note/DM00182773.pdf
https://www.onsemi.com/pub_link/Collateral/AND9071-D.PDF
Therefore I would like to know your opinion about the previous links and if there is anything else that should I have into account to do the PCB design of this IGBT driver…
Ahh and finally we are planning to use a Spartan 3A from Xilinx to handle the IGBT control lines. Xilinx is a good manufacturer for this applications or do you think that for this special application there are other manufacturers which can me provide me special EMC/EMI FPGAs?
Thanks for the help!
