T
treez
We need a discrete circuit which can detect whether or not an output is pulsing or not. (Pulse is 5V/0V) The ambient is 170degC so proprietory IC’s are not likely to be suitable. By “detect”, I mean say give a 0V output when there is pulsing and say a 5V output when not pulsing.
The application is a high duty cycle buck converter where if the gate drive duty cycle suddenly goes to zero, then the FET blows up. This is a common problem with DC restored, transformer coupled FET gate drives and is explained below fig 3 in the following…
Transformer coupled FET gate drive:-
https://www.eetimes.com/document.asp?doc_id=1273338
Article is based on "Gate drive design tips" by Ray Ridley.
