Replacement PIC With AVR
amirm2039
Newbie level 6
Newbie level 6
Hi Everyone,
Which AVR uC can be replaced instead PIC18F252?
In many cases you may develop a circuit to use either a PIC or an AVR.
Both usually will work.
But I don't think you find a pin compatible one, I don't think you find a full functionally compatible one and you won't find a code compatible one.
You can use XMega parts with big success. PIC controllers divide the clock on 4 to execute instructions (so 20 MHz clock results in 5 MIPS performance) where AVR parts use directly the clock - 20 MHZ results in 20 MIPS. So even smaller AVR controllers like ATMEGA88 which run on 20 MHz can outperform the PIC18F252. AVR timers are more complex than PIC ones, you have plenty of RAM - I think you'll not sorry about moving to AVR.
Thank you for taking this into consideration,
In fact, I want to use this for Serial Interface(RS232).
If this is your only specification, then almost any microcontroller has built in UART.
But at least you should additionally specify expected baud rate.
Just look at selection guides.
Thank you,
But, How can I matching the frequency for timers?
they won´t be code compatible. So you have to read the datasheet.
