graygem
- Joined
- Sep 21, 2010
- Messages
- 33
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,508
I am making a Class D amplifier that I am powering with a external 40Vdc power supply. I want to put in a power on LED, but the LED resistor calculator that I used said, "With a supply voltage of more than 24V, you'll dissipate excessive heat in a current-limiting resistor." Is there a better way to do a power LED using this higher voltage?
