manishanand14
Full Member level 4
- Joined
- Sep 3, 2011
- Messages
- 204
- Helped
- 10
- Reputation
- 20
- Reaction score
- 9
- Trophy points
- 1,308
- Location
- Bangalore ,India
- Activity points
- 2,584
I made this circuit.When i am giving 5 v pulses i expect to get 15V pulses at the output.Instead I am getting 5 V pulses itself.
What may be the reason.
I tried with BD139/Bd140 complementary also.
Will you explain in detail please !The circuit is functioning fine, it should put out pulses from 0 to 4.5V, approximately. That circuit will increase the drive strength of the input, but won't increase the voltage range.
Well then tell me how will i convert it to level translatorif you want 15v output , then you need to modify the circuit as level translator.
