How to print only the top layer in Orcad Layout?
bader
help in orcad layout
how can i print in layout a top layer alone without the bottom layer .........
Re: help in orcad layout
I'm not sure which version you're using but most packages do this the same way - - you will probably need to go into the options section of either the print command or the export command (may be called something else in your package - but it is what you would select when you want to output gerber files, etc.) If this gets you to the right place then just select only the layer which you wish to print and turn all others OFF.
this is my problem in the picture i can not print the top layer alone
Hi badder,
you can print the layout files in the folling way.
1. options-> post process settings
2. window -> tile
3. click on selected layer(means top, bottom etc..)
4. right click on that, than print.
    bader
